Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 4 door xj with 60/70 with coilovers
View Single Post
Old 01-14-2016, 06:03 PM   #1 (permalink)
nickjc13
Member # 89107
Well, I've lurked around here for a few years looking at all of the different builds. I finally decided to step it up on my build. Before I was running a trussed locked/d30 and 8.8 with bds 4 link in the front and bds leaf springs in the rear with 36" iroks.
Here are the Plans:
Front coilovers
79 ford kingpin 60 with 1 Reid knuckle
5:13 gears
Welded
35 spline outers
35 spline Yukon hardcore locking hubs
Artec full truss with ram mount
Trac bar mount
Psc double ended full hydro
Disc brake brackets and rotors setup to clear 15" rims (even though I will no longer be using 15s)
79 ford e350 Dana 70 rear.
Diy disc brake brackets and rotors/calipers setup to clear 15" rims
5:13 gears
Detroit locker
Yukon cut to fit chromoly shafts
Leaf spring swap
Anti wrap
Tires:
38.5 maxis creepy crawlers
16" stazwork double beadlocks
Inside:
Cage
Corbeau rs seats
Pics to follow
nickjc13 is offline   Reply With Quote
