Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Willys TJ Build
Thread: Willys TJ Build
View Single Post
Old 01-30-2016, 02:22 PM   #90 (permalink)
sigseth
Member # 464625
Originally Posted by Skip44 View Post
How much oil and what kind goes in these?
Skip
Lubrication: 6 oz. SAE 30 (non-detergent)
This looks like hardly any oil when you put it in the case, but it just needs enough for the lower gear to pick it up and smear it between the gears. Too much and it will begin to leak through the drum seal. The bushings for the drum won't benefit from the oil, in fact the support side of the drum receives no lube at all. Adding another 6 oz probably won't be a problem, but might make a mess. If you have winch rope, it could discolor it if it leaks through the drum onto it.
sigseth is offline   Reply With Quote
