Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 22R to 22RE swap FAQ
View Single Post
Old 01-03-2005, 09:11 PM   #2 (permalink)
Izeloz
Member # 30087
Send a message via MSN to Izeloz
1 –
FPU – FUEL PRESSURE SWITCH (B/Y/R)
ACV – AC IDLE-UP SWITCH (W/G)
*W – CHECK ENGINE LIGHT (V/R)
AS – AIR SUCTION VSV (L/R)
T – CHECK CONNECTOR (G/Y/R)
TSW – COLD START INJECTOR TIME SWITCH (G/B/R)
IDL – TPS (B/R)
*HT – O2 SENSOR (G/Y/R)
*IGF – IGNITER (BR/W)
E2 – GROUND (BR/B)
OX – O2 SENSOR (B)
VF – CHECK CONNECTOR (GR/B/R)
VCC – TPS (W/R)
KNK – KNOCK SENSOR (B)
VTA – TPS (L/R)
*NE – IGNITER (B/R)
THW – COOLANT TEMP. SENSOR (G/R)
2 –
E01 – GROUND (BR)
E02 – GROUND (BR)
10 – INJECTOR (W/R)
20 – INJECTOR (W)
STA – START SWITCH (B/R)
*IGT – IGNITER (B/Y)
STJ – COLD START INJECTOR (G/W/R)
E1 – GROUND (BR/W/B)
*NSW – START CIRCUIT ON IGNITION SWITCH (G/R)
3 –
VC – AFM (L/R/R)
E – AFM (BR/B/B)
VS – AFM (Y/L/R)
*4WD – 4WD INDICATOR LIGHT (R/Y/B)
THA – AFM (Y/R)
*SPD – SPEED SENSOR (G/R)
*BAT – EFI FUSE (W/L/R)
*B/K – STOP LIGHT SWITCH (G/W/R)
*B1 – MAIN EFI RELAY (B/R)
*B – MAIN EFI RELAY (B/R)
*-wire needs to be cut at the computer plug and spliced into existing truck harness
B – BLACK
BR – BROWN
G – GREEN
GR – GRAY
L – BLUE
R – RED
V – VIOLET
W – WHITE
Y - YELLOW
Izeloz is offline   Reply With Quote
