Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Jeep YJ Wheelbase Stretch Kit
View Single Post
Old 04-27-2016, 10:35 AM   #9 (permalink)
MotoBilt
MotoBilt's Avatar
Member # 218171
Send a message via Skype™ to MotoBilt
The Motobilt Jeep Wrangler Wheelbase Stretch Kit is designed to use Jeep XJ rear leaf springs on the rear of your Jeep YJ (1987-1995). Installing this kit moves the rear axle back about 6 inches. The kit incorporates a custom rear bumper and shackle hangers in one part. The shackle hangers are positioned high on the bumper to keep the overall Jeep ride height lower for better center of gravity. The ends of the bumper are tapered in to allow better clearance for the shackles with the rear axle at full droop. The kit comes with a custom set of leaf spring shackles designed to clear the bumper in the range of movement. The rear bumper also features 3/4" thick d-ring recovery mounts that pass through the bumper and welded on both sides. The bumper welds to the back of the factory cross member and has two side frame plates to cover the sides.
This kit does include new spring shackles as noted. The shackles are CNC laser cut from 1/4" high strength steel plate. The shackles measure 4 inches center to center and do have a 3rd cross bolt for additional support.
FEATURES
The bumper is 3/16" laser cut steel plate
3/4" thick d-ring mounts
incorporated shackle mounts
moves the axle back 6 inches
measures 42.5" wide
Includes new shackles and shackle spacer
This is considered a builder kit. it does require a qualified welding professional to install. The kit is considered off-road use only. The kit does not include poly bushings for the shackles. The kit does not include Jeep XJ springs. The Kit does not include a traction link or provisions to relocate the rear shocks. You will also need to supply parts to move your rear brake line.
MOTOBILT, INC.
Call Dan DuBose or Bobby Cox
334-219-2333
Check us out on the web:
Visit our Facebook Page:
MotoBilt is offline   Reply With Quote
