Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - CJ7 REHABILITATION
View Single Post
Old 05-14-2016, 06:10 AM   #8 (permalink)
wramblerguy
wramblerguy's Avatar
Member # 228970
Originally Posted by JBW5 View Post
I've had my heart set on building the set of Dana 44 scout axles I currently have collecting dust. Just a rebuild with 4.56 and trutrac. While I was about to order parts earlier i ran across this article on Randys Worldwide https://www.ringpinion.com/Technical...earend_yet.inc
It makes some pretty good points about the dana 20 that I currently have and I also have 1 piece axles already installed. The downfall is I would have to keep running spacers which is not really a big deal I guess. What do yall think? Dana 20 or Dana 44?
The cj amc 20 struggles because of the weak housing and weak 2 piece shafts
The ring and pinion is much larger and the shafts are the same strength at the splines
I would throw a simple truss on it, one piece shafts and run it
That is as long as you don't plan on ever running gears deeper than 4.88
I'm probably one of the only people to swap an amc 20 INTO a jeep haha
Build thead stalker
www.greatlakes4x4.com/showthread.php?t=236415
wramblerguy is offline   Reply With Quote
