Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 2 stroke Detroit diesels
View Single Post
Old 09-06-2016, 09:26 PM   #65 (permalink)
thordehr
Member # 86797
I've always wondered bout shutoff plates, butterflies failing or sucking air through broken gaskets and being unable to shutoff a runaway...
Would this be a good solution...
Plumb a fire suppression system, maybe even a handheld halon(or CO2) extinguisher with a hose extension to intake tract (like you would a before throttle blade intake nitrous nozzle). Have a runaway, trigger the extinguisher, it kills the combustion event, you don't risk sucking anything into the intake, you don't have the situation where you activate the plate or valve and it doesn't quite cut off enough air. Plus you're not sucking all the intake seals to death.
Whaddayathink?
1983 CJ-8 "Gossamer" FULLY POLISHED LS1, TH-400, Atlas 3.8:1 32 spline, 4" 0.375 wall driveshafts, Avalanche Titan axles, 2 1/2 ton third members, CTM axle shafts and Ujoints, ARB's, 15k Warn, Onboard welder and CO2, Halon and Coldfire extinguishers. CB, HF, PA, Sirens, Etc.
Threadkiller
thordehr is offline   Reply With Quote
