Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 2 stroke Detroit diesels
View Single Post
Old 09-06-2016, 11:22 PM   #73 (permalink)
[486]
Member # 192237
Originally Posted by Camarogenius View Post
When a 2 stroke diesel runs backwards,the intake and exhaust still function normally. The direction that the crank turns makes no difference.
The only issue I'm aware of is the oil pump may be direction sensitive.
you're an idiot who talks about shit he has NO FUCKING CLUE ABOUT
the blower is driven off the timing gears and is the only thing moving air through the engine
so yes it'll smoke out the air cleaner
and if you load it down hard it'll scuff up the rotors from the heat of pumping exhaust
ETA: but yeah the oil pump don't work going backwards either
[486] is offline   Reply With Quote
