Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - GenRight Offroad Semi Valley, CA
View Single Post
Old 01-30-2017, 07:41 AM   #21 (permalink)
2big bronco
2big bronco's Avatar
Member # 66684
You sound like a whiny pos. No wonder you cant get any help. You have a wheeler that is going to require constant attention and maintenance the whole time you own it. If that's not for you then maybe you should look into a stock honda civic.
Your ability to not spend a few hourss to solve the problem attests to my previous comment.
Have you went into the newbie section and asked how to get it to seal? I'll bet if you pull it apart, clean everything really good, use toyota or right stuff gasket maker, and re install the bolts with locktite or lock washers you dont have any problems. If they still work loose tack weld a few random bolts. Problem solved.
2big bronco is online now   Reply With Quote
