Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Ecoboost Maintenance
View Single Post
Old 08-12-2017, 08:42 AM   #322 (permalink)
D45
Member # 102974
Again, simple.......simple install
As easy as removing the top nut and removing the bottom nut, do this on both sides first
Then, just lift up the end of the sway bar about 2" and the stock end links will come right out
I did not have to use a jack or anything, just my cordless impact driver
On the reinstall, it did help to turn each tire/wheel out of the way slightly
The stockers did not have a zerk grease fitting, but these Moogs did
I was kind of surprised that the two mounting nuts were not nylon lock nuts, so I used some blue Loctite on reassembly
The Moogs also did not come with a grease fitting cap, thankfully I have a few on hand
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote
