Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - A340 trans question
View Single Post
Old 09-17-2017, 09:40 PM   #27 (permalink)
Mr Stubs
Member # 102813
I'm just brainstorming here so bare with me (I have a AW4
In my crawler)
If you make the block off plate and allow for a small return hole at the top of the plate, what would be the issue? It would turn more into a baffle, holding the rear full of fluid while the front stays inside a operating level. Put the nose in the air, the rear is still full and fluid isn't lost in the front, starving the pump. Small ports fill the rear on flat ground, the rear chamber just fills till the fluid makes its way out the small hole at the top of the baffle, refilling the front section.
[/COLOR]
Mr Stubs is offline   Reply With Quote
