Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - A340 trans question
View Single Post
Old 09-19-2017, 08:13 AM   #28 (permalink)
lambertvr4
Member # 210689
I've noticed that fluid still gets to the rear as well, but I still haven't had an issue with starvation I did before blocking off the lower plates. Once I blocked off the plates the trans has pretty much been a non-issue compared to before. I haven't even drained the rear fluid. Maybe I'll go do that to see how much comes out to add to this thread as an update.
The only issue I have now is that I'm not 100% sure that the trans is going into first gear. Mine is in an FToy and is not ECU controlled. The previous owner setup some wiring with relays that allow it to run "right" and shift manually. I can lockup the TCC with a button too.
Anybody know the wiring for these?
Originally Posted by 4bt40 View Post
So in entirely blocking off those lower galleys the fluid feeds in along the output shaft of the trans, and then has nowhere to feed back through causing it to just fill that empty cavity.
Has anyone else entirely blocked those lower galleys and experienced this?
-Lambert
lambertvr4 is offline   Reply With Quote
