Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Y61 ZD30 bell housing dimensions
View Single Post
Old 03-23-2018, 10:14 AM   #3 (permalink)
sebek
Guest
Member #
Posts: n/a
Hi.
I want connect gearbox from ZD30 to other engine. I'm not sure for this moment which engine I will use because I will have a lot of issues with space in my frame and front axle. I have few ideas for different engines.
I need bolt pattern of engine ZD30 or gearbox (this are the same dimmensions). Then I will try to make 3D simulation of adapter plate to connect this gearbox to other engine. On the end I will make probably twin disc clutch.
I need something like this (this is pattern for one of engine that I am thinking about):
