Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Sidekick IFS Tie Rod End Relocate
View Single Post
Old 05-17-2018, 07:35 AM   #3 (permalink)
southpark
southpark's Avatar
Member # 771825
Originally Posted by Gwagensteve View Post
You won’t have bumpstop now, but you will if you flip the tie rod end on the knuckle.
I assume you meant bump steer, if not bump stops are in place. I am going to do some measuring this weekend on the 2 door. From rough measurements if I move tie rod end to top of the arm it puts it back where it was before lift, albeit inverted. Thanks for the comments, looking for feedback, as at the point it is an idea not sure if it is good or bad.
southpark is offline   Reply With Quote
