Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 78 Wagoner 4d. Starting issues
View Single Post
Old 09-04-2018, 12:06 AM   #1 (permalink)
Jokerrw4
Member # 782041
Greetings.
I have a 78 with 360. I have replaced both power cables. New remanufactured starter, New starter solenoid,
Sometimes it will not crank over. Leave it for a couple of days starts up no issues.
When you start the Jeep at s and I terminal what should the voltage be?
I terminal starts out at around 6.9 volt and slowly builds up to 12.2 v. S terminal is a monetary 9.4v.
What would happen if the solenoid doesn't have 12v`s
And in theory to by pass the ignition switch I have to have 12v to terminal s which goes to coil and a monetary 12v to terminal S.
Sent from my SM-T350 using Tapatalk
Jokerrw4 is offline   Reply With Quote
