Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - The Welfare Duty
View Single Post
Old 11-13-2018, 09:46 AM   #110 (permalink)
snowracer
snowracer's Avatar
Member # 141697
got the front end stripped down this weekend to get ready for the 3 link and exo cage as well
the plan for the front was a set of 78/79 Bronco Deaver coils, Ballistic adjustable upper coil buckets and an Artec 1ton JK swap truss. he went and ordered all the parts and then actually looked at the truck and realized that the coils would not fit on the truss and clear the frame. only way to make it fit would be to build big mounts off the truss and inner C kinda like what comes on the 05 and up superdutys. he does not want to do that so now we will make the truss work and will be running a set of 14 inch coil overs.
jk 1ton swap truss, lots of extra parts that we wont be using now but do like how low it sits on the diff so will be nice for oil pan clearance
cleaned the 60 up and tacked the truss together and looks like it will need some trimming to make it fit the diff as back side is hitting some of the cast webbing on the center section. but should be able to make it work
PLAN-B F250 on 44s
snowracer is offline   Reply With Quote
