Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Transmission mount critique
View Single Post
Old 12-02-2018, 01:28 PM   #3 (permalink)
cj7jeep81
cj7jeep81's Avatar
Member # 15718
Originally Posted by SLOWPOKE693 View Post
Sounds legit. Just make sure there is going to be enough room for your exhaust to get by and you should be good to go.
Thanks, I thought it looked ok. The exhaust was run between the transfer case and the frame rails, so should still fit. Hoping to get this started tomorrow, and mount the body on the frame as well. Then make the last few parts to tie the roll bar into the frame, and then the shock mounts. Then finally take the body off, drive train out, axles off, and paint the frame. This has taken way longer than I thought it would, but its getting there. Just sucks now as I'll have to rent a space heater to paint the frame, ran out of natural heat.
cj7jeep81 is offline   Reply With Quote
