Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Boardbysled's Budget Buggy Build
View Single Post
Old 01-13-2019, 10:10 PM   #60 (permalink)
boardbysled
Member # 136471
More work.
I try and update my instagram pretty frequently if you want to follow along.
https://www.instagram.com/jacob.l.vail/
Started on the passenger side header, had to shorten it quite a bit to fit around the upper link, essentially made the 'longtubes' into 'midtubes'. Still needs finished and welded. Driverside will need shortened as well to fit around the driveshaft.
Started stripping stuff off the rear of the chassis for final welding.
Took the fuel cell apart to put the fuel pickups in. The inside of the steel shell is unpainted and shitty expanding foam in the bottom. So added some paint and slightly enlarged the drain holes to hopefully limit the amount of rust. Will add some foam strips back in when I put it back together.
boardbysled is offline   Reply With Quote
