Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - In Design phase, 4-link question
View Single Post
Old 01-21-2019, 03:39 PM   #11 (permalink)
Provience
Custom User Title
Provience's Avatar
Member # 138976
Originally Posted by Quick & Dirty View Post
A quick search didn't turn up the actual law, but there has to be a mechanical connection between the steering wheel and the wheels. No purely hydraulic or electrical steering.
If you use a conventional steering box and drag link with a triangulated suspension, you will likely have bump steer. The axle needs to move in an arc that matches the motion of the drag link. Side steer may work better than cross steering, depending on the link geometry.
that is what i have yet to find.
NHTSA specifies that you must make it so that there is passanger protection from the steering. i.e. collapsable steering shafts so that you don't get impailed.
49 CFR talks about joint slop and steering input slop.
unless there is a state specific thing, i am very interested in finding a federal requirement. there does not seem to be one.
edit: this article talks about the infiniti Q50 that uses "steer by wire" https://www.wired.com/2014/06/infini...steer-by-wire/ and is road legal
Provience is offline   Reply With Quote
