Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - In Design phase, 4-link question
View Single Post
Old 01-22-2019, 06:37 AM   #14 (permalink)
BioHazard2222
BioHazard2222's Avatar
Member # 164729
Originally Posted by Quick & Dirty View Post
A quick search didn't turn up the actual law, but there has to be a mechanical connection between the steering wheel and the wheels. No purely hydraulic or electrical steering.
If you use a conventional steering box and drag link with a triangulated suspension, you will likely have bump steer. The axle needs to move in an arc that matches the motion of the drag link. Side steer may work better than cross steering, depending on the link geometry.
Q&D, I was going to use a conventional steering box for this project. Since I'm new to this, I guess I need to look into side steer. Would you have any references for laying out the 4-Link and making a conventional steering box work properly?
Like I said, I'm still in the design stages, so any suggestions are are very much welcomed.
BioHazard2222 is offline   Reply With Quote
