Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 02 Dakota Quadcab Crawler
View Single Post
Old 01-22-2019, 06:50 AM   #119 (permalink)
'Mad Max'
'Mad Max''s Avatar
Member # 110114
...painted the tranny to match - it was upgraded with a bunch of leftover Cummins 47RH hardware including the input shaft and pump, drums and clutches, and overdrive unit (with a gasser governor) - it's now essentially a gasser 46RH with Cummins guts. I'll swap on the B&M deep pan once I get the 46RE out from under the truck.
To finish it off I opted for a Hughes LXTM towing converter which should nicely handle the 440.
...and my Rogue Fab M600 xHD bender is ready to work -
the thing's a beast - made a perfect 190* bend in my 1-7/8 x .145 wall DOM tubing with near zero deformation
...and I drove the truck into the shop under 'Magnum' power for the last time - finally time for some real voodoo
Progress
02 Dakota QuadCab 4x4 - 440/46rh/Atlas4/D60/14B/40" Toyos (...in work...)
'Mad Max' is offline   Reply With Quote
