Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Project Piss Off My Neighbors and Set My Condo on Fire
View Single Post
Old 01-22-2019, 02:22 PM   #1139 (permalink)
gtxracer
NERD
gtxracer's Avatar
Member # 25303
Originally Posted by Chief Rocka View Post
Regarding CG height # and thinking it seems low @ 24.5". Is the general rule of thumb the upper bolt on the bellhousing, bottom bolt on bellhousing, crank centerline, or something else?
Thanks for bumping this to the thread. You may be right, seeing as how others use between 30 and 40 inches based on the vehicle ride height. I think I'm a bit low and low 30s is more accurate. This essentially lowers the AS. I tested it in the calculator and it lowers the AS about 10-20 points.
More threads on how to calculate vehicle CG height (center of gravity) here:
https://www.pirate4x4.com/forum/newb...r-gravity.html
https://www.pirate4x4.com/forum/jeep...avity-how.html
https://www.pirate4x4.com/forum/jeep...clearance.html
Originally Posted by fcope002 View Post
Looking good man! I tell you what, you get spoiled with CNC plasma cut brackets. Its painful for me to make tabs manually now haha
Thank you sir! I do feel spoiled and I love it. Let me know if you need some tabs cut I have 1/8, 3/16, and 1/4 A36 sitting here.
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote
