Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - *FAQ*What tcase gears should I (or you) buy?
View Single Post
Old 01-23-2019, 07:46 AM   #9 (permalink)
Diesel_Zuk
Member # 207522
Basic description of rig: Samurai, diesel swapped, stretched 18", steel flatbed, lot heavier than stock.
Engine: 1.9 TDI
Transmission: Geo tracker 5 speed
Transfer case(s): Geo tracker, twin sticks, 4.24 gears, slip yoke eliminators.
R&P: 3.73
tire size: 33x12.5x15, worn out, actual measurement currently, 31.25"
Type of wheelin you do: Rocks, mild trails, Moab, other Utah wheeling, etc.
How you like it on the highway: high range is too high with the 3.73's and 33's, I went with the tracker tcase to try to lower my high range RPM's at high way speeds, but it's just quite a bit too low.
How you like it offroad: Does good offroad, climbs easily without much if any throttle.
If you had to do it again whats gears would you buy: I'm planning on swapping in 5.13 gears in the very near future, in order to be able to daily it a little better.
Diesel_Zuk is offline   Reply With Quote
