Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 12v Minivan, not enough power-4 problems
View Single Post
Old 02-11-2019, 08:49 PM   #29 (permalink)
v30crewcab
v30crewcab's Avatar
Member # 687834
marine pistons should be fine, but ditch the 20 over head gasket, unless you decked the block or the head alot. its killing your compression. not sure how much the marine pistons lower it, mainly they have a larger bowl for the wider spray of marine injectors or higher timing. anything over 18-20 degrees of timing is going to kill your bottom end for a stickshift.
88 chevy crewcab 6bt nv4500
72 scout 60/14b 40's
v30crewcab is offline   Reply With Quote
