Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Zuk Based JHF/Goatbuilt Buggy
View Single Post
Old 03-20-2019, 05:39 AM   #238 (permalink)
j20brett
Member # 113606
Originally Posted by sleepsontoilet View Post
I've had a few questions about my fix, so I figured I'd post a couple pics to help someone. Having just ripped a 3/4 heim in half I figured I would share what I learned this weekend. Trail Gear 3.5 9" housing using 05+ Superduty Cs and outers with stock Spicer 1550 shafts and a PSC 2.5x10 ram.
I ground the back side stops flush with the knuckle until I just had daylight between the caliper and shock. If you inboard the shock more, you could probably grind some more.
I ground about 1/2" off the lower steering arm of the JHF kit until there was barely daylight at full lock.
Are you not worried about too much steering angle now? I mean, those shafts are going to have a ton of stress at full lock from what it looks like. Did you measure the degree of steering you are getting?
Fight Crime...Shoot Back.
[SIZE="4"][COLOR="Red"]ΜΟΛΩΝ ΛΑΒΕ[/COLOR][/SIZE]
[QUOTE]Originally Posted by [B]Muddin [/B]
It wasn't a little "achoo". It was "achsshemmiddtpppthpphphphphtsmmmppp...spray".[/QUOTE]
j20brett is offline   Reply With Quote
