Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Jeep 5.9L and AW4?
View Single Post
Old 03-21-2019, 11:30 AM   #7 (permalink)
ky scrambled
Member # 85771
Originally Posted by Byro View Post
My thoughts exactly.
The only issue I could foresee is the flex plate/TC. Iím sure Novak or AA has something if a mixture of OEM parts will not work.
Also does the 5.9 use a bellhousing mounted CPS? That could be another issue.
Flexplates below
4.0
Ring Gear Tooth Quantity: 164-tooth
Engine Balance: Internal
Flexplate Material: Steel
Notes: 13.81 in. outside diameter, 12 pitch.
5.9
Engine Balance: External
Notes: 11.5 in. outside diameter.
Looks like the 5.9 has a CPS in a very similar location to the 4.0.
Make Forums Great Again!
ky scrambled is offline   Reply With Quote
