Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Budget friendly portals for ifs build
View Single Post
Old 03-25-2019, 10:49 PM   #14 (permalink)
YotaAtieToo
YotaAtieToo's Avatar
Member # 25632
Originally Posted by 65Chevy4x4 View Post
Would running a portal to reverse driveline double the load and rpm of the front diff making it essentially weaker than stock.
H1 portals are 1.8:1 irrc. So in order to "undo" the gear reduction at the wheel, you'd have to overdrive the pinion 1.8:1, which seems like a bad idea, not to mention the weight and complexity.
Running 9" front and rear would make it relatively easy to match your ratios front to back like you mentioned earlier.
YotaAtieToo is offline   Reply With Quote
