Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Budget friendly portals for ifs build
View Single Post
Old 03-29-2019, 10:21 AM   #30 (permalink)
posford
Member # 143737
Originally Posted by Action Fab View Post
The way I figure, you can just cut the factory front housing at 4" out from the center section, flip the diff and then use the Synergy sleeve kit to weld the housing back together.
Fuck that, theres tons of chevy 10 bolt fronts laying around, flip the bitch for drivers side drop and reversing the gears, plenty of axle tube to lop off the inner Cs and add whatever C you want to match the portal, and get the correct width without splicing axle tubes together
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote
