Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Budget friendly portals for ifs build
View Single Post
Old 03-29-2019, 10:31 AM   #31 (permalink)
Action Fab
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Originally Posted by posford View Post
Fuck that, theres tons of chevy 10 bolt fronts laying around, flip the bitch for drivers side drop and reversing the gears, plenty of axle tube to lop off the inner Cs and add whatever C you want to match the portal, and get the correct width without splicing axle tubes together
You probably don't know the principal behind my chassis. The idea is that you bolt everything from a XJ/ZJ/TJ into it and it makes a budget friendly, very small lightweight buggy. With the stock 61" wide axles, 35's and a 102" wheelbase, it's scaled down.
I don't understand why you'd need to switch the dana 30 to a 10bolt. These buggies already make dana 30's live with 35's and 37's without the reduction of portals and with the heavier/more powerful 4.0.
My whole goal with portals and the dana 30 was to prove they would live under hardcore use with big tires. Even though I've proven several times you don't need big tires for hardcore wheeling.
I definitely understand that I build unconventional stuff that most people think won't work.
For reference this is a Tomahawk on stock axles and 37's. There is plenty of room in the design to shove the axle up into the chassis a few more inches.
Action Fab is offline   Reply With Quote
