Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Box truck to RV conversion. Crew Cab f450
View Single Post
Old 04-01-2019, 11:03 AM   #1101 (permalink)
Java
Member # 56256
Originally Posted by ky scrambled View Post
You rely on other climbers mounting those bolts/tie off spots?
Yep.... This area is really well bolted, half the routes (IIRC there are like 700 routes) are bolted. You do rely on someone else, but they are generally replaced as needed. Even most of the trad routes here have top anchors. There are only a couple I avoid due to loose bolts.
F450 Box Truck to RV conversion www.NWadventuretruck.com
Java is offline   Reply With Quote
