Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Cracked gear driven transfer case?
View Single Post
Old 04-09-2019, 09:36 AM   #1 (permalink)
ccantr10
Newbie
Member # 143255
I tried searching with no luck....
A friend and I both experienced the same crack in our gear driven transfer case on the same ride in the same day. Both are setup the same with 22RE / W56 / dual cases / 4.7 gears in the rear case / Trail Gear cross member skid plate / square front driveshaft.
The crack was on the outside of the drop to the front output just above the drain plug.
I rarely post anything so it may take a few tries to get pictures to attach, any help would be appreciated.
So... Has anyone experienced this issue or know what could be causing it? I feel like it would be a hell of a coincidence to happen the way it did, if they are unrelated.
ccantr10 is offline   Reply With Quote
