Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 02 Dakota Quadcab Crawler
View Single Post
Old 04-09-2019, 09:42 AM   #131 (permalink)
'Mad Max'
'Mad Max''s Avatar
Member # 110114
once the alignment was confirmed, lots of gusseting with 1/8" plate (same thickness as the frame) -
top and bottom plates like these (top is 1/8", bottom is 'rock-resistant' 1/4") -
boxed completely all the way back with 1/8" -
and then in-boarding/lifting the cab and core support mounts enabling the use of all the OE bushings and bolts -
Of course there's plenty of finish welding and such, but it's done enough to continue with mock-up, and then comes the engine and trans mounts, belly cradle, gas tank mounts, and finally, "suspension".
02 Dakota QuadCab 4x4 - 440/46rh/Atlas4/D60/14B/40" Toyos (...in work...)
'Mad Max' is offline   Reply With Quote
