Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 02 Dakota Quadcab Crawler
View Single Post
Old 04-09-2019, 11:24 AM   #133 (permalink)
'Mad Max'
'Mad Max''s Avatar
Member # 110114
current plan is to access the spare from above via a big trap door in the bed. Thought about dropping it out the bottom same way the factory did it, but I'll need the height under the bed to get the tire up high enough to clear the 14b so I'm removing most of the bracing under the trap door and I'll use the spare itself to 'support' that portion of bed floor...at least that's the plan. Considering the bed won't be carrying 'massive' loads there shouldn't be any problems. Not planning to fab up a 'well' for the tire to sit in - it won't need to be 'sealed', just a basic cage to contain the tire, plus some kind of rock/debris shield. Meh - that'll likely sort itself out once I start fabricating things - see what works and what doesn't...
02 Dakota QuadCab 4x4 - 440/46rh/Atlas4/D60/14B/40" Toyos (...in work...)
'Mad Max' is offline   Reply With Quote
