Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - walk in cooler help
View Single Post
Old 05-15-2019, 08:28 PM   #26 (permalink)
waterhorse
Member # 181868
Originally Posted by Grumpy356 View Post
Call it a freezer, call it a cooler, it doesn’t matter,
A 35 degree chamber temp (which he said it was maintaining ) will require a coil temp of less than 32. Which means defrost.
Not true. I have a walkin cooler that the fans run 24/7. The compressor runs when needed. Yes, the evaporator is below freezing and collects some ice, but whenever the compressor shuts down, the fans are blowing "above freezing" air through it. It melts the ice, drips on a pan and drains out the side.
We also have a walkin freezer. It has a much more complicated system because there is no "above freezing" air to defrost the coils.
Project : Amphibious HEMTT
waterhorse is offline   Reply With Quote
