Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - useless things about your day you want others to know. gcc
View Single Post
Old 05-17-2019, 06:40 AM   #3315 (permalink)
thumping
Member # 85483
Originally Posted by [486] View Post
SD coil buckets bolt up, or you can weld up the tops of the TTB ones to fit the SD coils
use the SD radarms and frame brackets, hell, even the track bar bracket pretty much bolts up
steering linkage ain't bad, you just use a 4wd f350 pitman to get the full steering range
big bore MC from an f-superduty is like $20
front driveshafts are easy to cobble
And you might as well throw a the $150 10-1/4 in the rear and buy some matching wheels. After you've replace the axle bearnings, brakes...etc.
I'm with 45....throw a HP44 in it and ride. Most people aren't bouncing their DD.
Today, truth has been forced to take a back seat to political correctness
thumping is online now   Reply With Quote
