Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - useless things about your day you want others to know. gcc
View Single Post
Old 05-17-2019, 06:40 AM   #3316 (permalink)
ky scrambled
Member # 85771
Originally Posted by [486] View Post
SD coil buckets bolt up, or you can weld up the tops of the TTB ones to fit the SD coils
use the SD radarms and frame brackets, hell, even the track bar bracket pretty much bolts up
steering linkage ain't bad, you just use a 4wd f350 pitman to get the full steering range
big bore MC from an f-superduty is like $20
front driveshafts are easy to cobble
A SD 60 pretty much bolts up to a big bronco? Sweet!
Make Forums Great Again!
ky scrambled is offline   Reply With Quote
