Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Shocks on a Bronco question. Drives like a boat.
View Single Post
Old 06-17-2019, 01:34 PM   #21 (permalink)
Mr.RatBastard
Mr.RatBastard's Avatar
Member # 9307
Originally Posted by mobil1syn View Post
are you running drop brackets?
did you drop the pitman arm?
did you lift the rear or solely relying on the bags for ride height?
Yes I have the drop brackets. Everything looks tight, I also replaced the pivot bushings. I have a 4" drop pitman arm and the TRE's on top of the knuckle. That got me pretty close to parallel with the beams. Technically this is 1" off parallel but the way Superlift had it was 2" off. I bought a new stock arm to put on if I switch to the 4" front springs. With the TRE flip I will still be 1" off.
I am running blocks in the rear. My stock springs still have a decent arch to them so I didn't think they were too worn out. The bags are adding about an inch of lift at 35psi. I also ordered a shorter block so I can keep the bags where I want them. and reduce the overall height.
Mr.RatBastard is offline   Reply With Quote
