Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Shocks on a Bronco question. Drives like a boat.
View Single Post
Old 06-18-2019, 08:18 AM   #36 (permalink)
arse_sidewards
arse_sidewards's Avatar
Member # 256962
Originally Posted by welndmn View Post
If you did not know, off the shelf shocks for Bronco/F150 are valved different for single shock, or dual shock front ends, so make sure you buy correctly, I don't know how Bilstien makes their part numbers.
Ford also didn't put 2 shocks on the front end as a nice feature, you need more damping to control the TTB. While the Bilstien is a quality shock, I don't think 1 will do, you need to step up to a 2.5 inch shock or dual shocks if you want performance out of it.
Ford put quad shocks on the Broncos and F150s that came with that option because it was the 80s and good shocks were few and far between so it was basically their "performance" option.
There's nothing special about the TTB that requires an extra shock.
arse_sidewards is offline   Reply With Quote
