Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Shocks on a Bronco question. Drives like a boat.
View Single Post
Old 06-18-2019, 01:07 PM   #43 (permalink)
welndmn
welndmn's Avatar
Member # 398
Originally Posted by arse_sidewards View Post
What is it about the TTB that turns people into mullet wearin', trailer livin', sister fuckin' idiots incapable of understanding middle school level geometry?
As far as the shock cares there's nothing special about the TTB. It's no more demanding of shocks than any other IFS. If anything it's less demanding because the motion ratio between the shock and the wheel is greater than that of your typical A-arm IFS with suspension pivots much closer to the wheel. The Monroe and KYB budget line shocks work tolerably enough on every other IFS vehicle. They work fine on TTB trucks.
Cheap standard shocks cause large amounts of tire wear on TTB because of the massive camber changes.
Do you know what un even tire wear is, the lack of contact with the ground.
Mark
welndmn is offline   Reply With Quote
