Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Driveline angle
Thread: Driveline angle
View Single Post
Old 08-01-2019, 07:32 AM   #1 (permalink)
macqueen785
Member # 852924
Driveline angle
I have a 1986 k10, has a dana 60 and 14 bolt with a rough country 6inch spring lift. I need to have a driveshaft made, but before i do i measured the angles to see how off they were.
The output shaft of the transfer case is 5 degrees nose up, while the pinion is 17 degrees nose up. That shows i need to roll the pinion like 12 degrees correct?
Thank you for the help
macqueen785 is offline   Reply With Quote
