Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Trailer frame bent
View Single Post
Old 08-12-2019, 12:40 PM   #2 (permalink)
Bo185
Bo185's Avatar
Member # 48545
If you can get it bent back straight and level, which I doubt not with out cutting it, then you need to box it were the suspension it. Its fixable just depends if you got time and can weld. If so remove the deck next to the frame there and go to town. I would plate the other side as well. It was pretty overloaded those look like 3500# axles and springs GVWR on trailer should be 7000k, and I assume 3/16'' angle.
One reason to crawl under a trailer and inspect. I am sure dude knew it was fucked up.
'73 IH Scout II Vortec 6.0L 4L65e np241
'73 IH 1210 Travelette SV392 V8, T34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote
