Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - F150 trans lines failure
View Single Post
Old 09-04-2019, 11:59 PM   #29 (permalink)
mwilliamshs
Member # 355210
Originally Posted by beakie View Post
...am I being unrealistic to expect some coverage/help from Ford?..
Simply put, yes.
You bought a truck with a warranty. You had the opportunity to buy an extension of that warranty but refused. So now, you own a truck without a warranty. It is in fact unrealistic to expect warranty coverage without a warranty.
I would get it from the dealer to an ordinary garage. Clear any codes. Disconnect the battery. Wait a day. Charge the battery for that day. Reconnect battery. Clear any codes. Check trans fluid. Fill if below full. Drive it. If it shifts erratically or throws codes, take it to the trans shop.
Was transmission service part of your maintenance package? Is there a transmission service they should have performed by now? Did they? Did they document the fluid level at that time?
mwilliamshs is offline   Reply With Quote
