Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 01 XJ Classic on Super Duty axles
View Single Post
Old 10-11-2019, 07:00 PM   #406 (permalink)
Craig6.9diesel
Member # 694345
Originally Posted by Boogs1970 View Post
My tcase is up little higher then stock, its an atlas t case so i cant bring it down much or it hits the transmission cross member. same joint setup that your running.
You could clearance the cardan joint with a die grinder. Or you could adjust your pinion angle.
Craig6.9diesel is offline   Reply With Quote
