Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - SD High Steer options - Weld on or machine?
View Single Post
Old 10-15-2019, 03:49 PM   #21 (permalink)
rockyota83
Member # 53528
Originally Posted by jsawduste View Post
And if you like good steering geometry you'll not use the Ford parts at all.
Ried C`s and knuckles set for 7-8* caster after you`ve set the pinion angle. TR to the cast in arms for Ackerman.
An even better way would be to toss the Ford center and buy an aftermarket center. That way your making the axle fit YOUR rig not the other way around.
Not a fan of the Ford at all...............Yes, its buy in is cheap but the ROI sucks.
seriously? wtf are you bringing up a fully custom axle when guys are asking about what high steer to run on a junkyard axle
reid knuckes and c's are going to cost almost 2k by themselves
rockyota83 is offline   Reply With Quote
