Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - 22re Burning Oil
View Single Post
Old 01-12-2020, 02:46 PM   #14 (permalink)
crash
crash's Avatar
Member # 1588
Break it down to where the oil can come from
-Valve Guides
-Piston rings
-pcv system
The first 2 require tear down to see whats going on. Oil from the PCV system is typically an after effect from excessive blow by--which stems usually from a sealing issue in the cylinder.
I always start with a leak down test--that can tell you quite a bit in regards to how the rings/valves are sealing...
Mike Crash Kash
crash is offline   Reply With Quote
