Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Rear drive shaft angle question
View Single Post
Old 01-12-2020, 05:55 PM   #1 (permalink)
split141
Member # 697425
What's up. So I've been sitting on this Samurai for a while. I'm taking out the rear shaft to either remake or balance the one I have. My question is in regards to the angle of the drive shaft. Right now the bottom flange is pointed probably 1 to 2 degrees downwards.
Should the rear diff point directly at the tcase, level to the ground or down a couple degrees towards the earth? I'd post images but I'm under 10 posts. Thanks.
split141 is offline   Reply With Quote
