Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Talk me outta this- 2018 Jamis Dragonslayer 26"
View Single Post
Old 01-31-2020, 07:58 PM   #10 (permalink)
FlexyTJ
Member # 40417
Originally Posted by donb View Post
Anyway - I would suggest a modern 27.5 full sussy rig if you can swing it price wise. PB just had an article on one for around $2k that they loved. If you are trying to keep it at that $1k price point then a modern geo 27.5 or 29Ē HT from the PB classifieds or FB Marketplace as guys are always upgrading.
Iím on a 3rd Gen Santa Cruz Nomad C that I built up from mostly used stuff last year. It is crazy how much it can do (lift assist to multi hour pedals) and itís dated at this point.
Thanks for your input, good food for thought.
Originally Posted by 94toytruck View Post
26 vs. 29 is a huge difference, 26 vs. 27.5 hardly noticeable, 27.5 vs. 29 still a pretty big difference. A 27.5+ is roughly the same OD as a normal 29 though. All of my bikes are 27.5 or 27.5+ except my old Banshee Paradox which is bolted into a trainer with a 700 road tire on it. I personally like 27.5 better, its a stronger wheel, for me I can interchange tires back and forth and I feel its a bit easy to move around. A 29 does have better roll over if your riding rough terrain which is something to really consider.
My Primal is aluminum, its a plus bike the tire absorb a ton. I bought the frame new as a leftover. Everything else was used, cheap or I had it.
Frame-new ebay
Headset-new ebay
Marzocchi NCR350 - used had
Stans Sentrys, Recon 2.8s and cassette - used ebay
Sram XO crank, BB and 32 ring - used
Shimano 11spd der/shifter - used
Chromag BZA bars - used had
Chromag Hifi 35 - new ebay
Grips - freebies
KS LEV - used - ebay
Hope x2 brakes - used had
OK so I had a few more parts than I thought but its a pretty badass bike cheap. I rode it more this year than my Slash by a good bit. Not sure if this link will work... https://www.instagram.com/p/B3algQeH..._web_copy_link
You had most of the parts
Thanks for sharing the build, I like that frame. I still have an old Soul Cycles Titan that I think has pretty similar geometry- was looking for something along those lines but in steel. The Titan I have is beat and is a 26'er- Good wall ornament though.
Originally Posted by 4x4junk View Post
Looks like a good deal $$ wise. It's hard to answer if it would be a good bike for you, not knowing where you ride. I would say, if you ride where the fat tires would help, a bigger diameter would help more. If the fat tires aren't needed I wouldn't want them. It looks like a fun bike though.
The terrain varies wildly here. I will probably use it mostly on buffed out desert single track (little elevation/smoother) vs. bigger mountain terrain with lots of elevation/rockier.
Better to be a racer for a moment, than a spectator for a lifetime.
FlexyTJ is offline   Reply With Quote
