Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Rear Disc Brake, SA to IFS rotor swap? Stupid?
View Single Post
Old 02-08-2020, 06:14 PM   #15 (permalink)
Provience
Provience's Avatar
Member # 138976
alright, some install pictures in case anybody is ever dumb enough to do this in the future, but is hesitant because there are no pictures
shaft post turning, lots of meat left there
studs that orielly had in stock, 1995 Toyota 4runner front studs
studs pressed in without issue
and everything all together using the pre-existing caliper mount. no real issues, though it seems like grinding a touch off the caliper ears would help. previous solid axle calipers had about a .090" shim (or so, I didn't measure or look closely)
the SA calipers were mounted about 1/16" too high, the IFS calipers using the same mounts are about 1/8" too high. I'm not sure that I will change the mounts....but maybe
certainly good enough for moving it in and out of the garage for a bit
Provience is online now   Reply With Quote
