Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Miller Multimatic 220
View Single Post
Old 02-15-2020, 05:44 PM   #9 (permalink)
DirtyComanche
Member # 53453
The comparable ESAB is actually the Rebel 205IC and it's $100 more for very similar specs. The main difference is you can adjust the A/C TIG quite a bit more. 5-235 amps on the ESAB vs 20-210 amps on the Miller, A/C balance is 60-90% on the ESAB vs 60-80% on the Miller, 25-400Hz frequency on the ESAB vs 60-150Hz on the Miller, and 1-500PPM pulse TIG vs 1-150PPM pulse TIG Miller.
Also I'm not sure if the Miller supports pre-flow for TIG, looking now, the ESAB definitely does (both do post flow). Also not sure if either do pre/post-flow for MIG.
DirtyComanche is online now   Reply With Quote
