Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - turn up the pressure on power steering pump.
View Single Post
Old 02-11-2006, 05:42 AM   #11 (permalink)
kjmcdaniel
kjmcdaniel's Avatar
Member # 31679
In the picture above, the piece on the right with the groove at the top....
Take two wrenches and take it apart. Inside, you will find a ball bearing and a spring. This regulates the bypass pressure of the pump. When pressure increases it pushes on the ball, compressing the spring and allowing fluid to bypass the pump vanes. I made a shim the same diameter as the spring, and about .070" thick, and put it in the bottom of the hole the spring goes in. At the opposite end as the ball.
Sorry, I don't have any pics, but if you have trouble, let me know, I'll try to explain better.
Team Easy!
2008 Rrock Series Champions - Legends
2004, 2005, 2006, 2007, 2008 Rrock competitor
2005, 2006, 2007, 2008 Top Shop competitor
Member in poor standing of the Rrock Mofia
kjmcdaniel is offline   Reply With Quote
