Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - For you guys usin air cylinders
View Single Post
Old 04-26-2006, 04:11 PM   #28 (permalink)
motorcitydak
motorcitydak's Avatar
Member # 54956
Send a message via AIM to motorcitydak
what is an exected pressure i can get out of an oba setup? if i run 5 inch cylinders, i should only need about 80psi or so, but if I can get 120psi in there, they would lift 2350lbs each, meaning I could lift a vehicle straight up and out of a hole or something. Basically, I would have an extra 2000lbs or so of lifting force on the front end if needed. The axles and mounts would then worry me, but it is possible.
motorcitydak is offline   Reply With Quote
